How to reset all credentials in Netsight?
  • Question
  • Updated 3 years ago
  • Answered
I can still login as "root" to the underlying linux VM for Netsight, but for some reason I can't authenticate to Oneview or the Java apps. I must have messed up something in the user database inside Netsight, but since this is a new installation I'd be happy enough just to start from scratch. How can I set the user database back to factory defaults in Netsight?
Photo of Reid Knuttila
Reid Knuttila
  • 170 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,884 Points 20k badge 2x thumb
So if I unterstand your post correctly you can't access the Netsight GUI.
If that is the case you might find the answer to your problem right here....
https://gtacknowledge.extremenetworks.com/articles/Solution/Unable-to-login-to-Netsight-Console-usin...
You'd set Netsight back to local authentication and as you've root access generate a new user to access the system - or use the root account.
If the installation is VM you'd also just delete the VM image and install from scratch....
