how to restart a port of B5 series switch (power down and restart)
  • 2
  • Question
  • Updated 1 week ago
  • Answered
I need to reset (remove voltage and restart) one particular port  whitch is connected a network clock.
This clock is in crash and I cannot go on site to disconnect the cable
Photo of Visconti
Visconti
  • 764 Points 500 badge 2x thumb
Posted 1 week ago
  • 2
Photo of Anton Sax
Anton Sax
  • 1,242 Points 1k badge 2x thumb
do you mean poe power?
set port inlinepower ge.1.x admin off
set port inlinepower ge.1.x admin auto
this should do it
Photo of Visconti
Visconti
Ok  I followed your advice and infact now I see the mac of the clock connected to this port but when I ping the ip I do not receive any feedback
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
If the clock get's the IP via DHCP check whether there is a renew of the lease.
If the clock has a static IP it could be that the device lost the config.
Photo of Martineau, John
Martineau, John, Employee
  • 812 Points 500 badge 2x thumb
If the clock has a static IP, the unstable state may have returned the device to factory default or is in a dead state.  IF IP is dynamic, please verify DHCP server sees request and has an entry in its database.
Photo of Baris Karabacak
Baris Karabacak
  • 110 Points 100 badge 2x thumb
As Anton said you remove the voltage with ...inlinpower.
But set port disable is also an Option to disable the network traffic.
Therefore: set port disable ge.x.y
set port inlinpower ge.x.y admin off
I prefer to wait at least one Minute and then restart the power and traffic:
set port inlinpower ge.x.y admin auto
set port enable ge.x.y
Why this?
i had an issue with a Controller. I tried several things. Then forgot to enable the port because of interruption. Then if i concentrated on the issue again, enabling the port, the Controller woke up.
May be you have a similar Situation.
Greetings from Nuremberg.
