How to schedule a reboot on VDX 6740
Al_Mat
New Contributor II
Hello!
Is it possible to schedule a reload on VDX6740? What is the command?
Thanks!
2 REPLIES 2
TechHelp24
New Contributor II
Hi Al Mat,
you should be able to do a reboot when unhide to fos command like:
VDX#unhide foscmd
Password:fibranne
VDX# foscmd "operand fastboot or reboot" ?????
but I'm not sure if that work
Mick_Day
There is no method to do this from NOS
Reload takes effect as soon as command is executed
Regards
Mick
