How to schedule commands on X430 ?
  • Question
  • Updated 1 year ago
  • Answered
  • (Edited)
Hello,
I need periodically to disable PoE on some ports to reset CCTV cameras (eventually reboot the switch).
I was able to write python script, which disables inline-power and then re-enables inline-power on interesting ports. However, X430 series doesn't support UPM, so I cannot create upm profile and configure timer fot this profile.
Any other ideas for scheduling some cli commands on X430 series ?
REGARDS
Robert
Photo of Robert Zdzieblo
Robert Zdzieblo
  • 1,186 Points 1k badge 2x thumb
Posted 1 year ago
Photo of Taykin Izzet
Taykin Izzet , Employee
  • 2,944 Points 2k badge 2x thumb
Per the v16.2.3.5-patch1-3 Release Notes:
Universal Port Management (UPM) on Summit X430 Series Switches
Support for Universal Port Management (UPM) is now extended to the Summit X430 series switches.
Robert Zdzieblo
Thanks you, Taykin !
I was using summitlite-16.1.3.6.xos image.
I'll check this functionality after update.
Robert Zdzieblo
Yes, UPM is working on new summitlite-16.2.3.5-patch1-3.xos image !
Thanks !
