How to setup WM3400 to act as DHCP
  • Question
  • Updated 3 years ago
  • Answered
I'm trying to separate my wireless clients IP useage from my wired clients.
Layout:
Office DHCP server 192.168.1.2 (scope = 192.168.1.0/24) (x.x.x.1-100 reserved)  --------- Wireless Controller 192.168.1.3 (Would like to use scope of x.x.x.200-249)
Is this possible, perhaps a manual?    I'm using a WM3400 Wireless Controller, DHCP is on Windows Server 2008 R2.
Photo of Sean Tutor
Sean Tutor
  • 568 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,254 Points 10k badge 2x thumb
Hi Sean,
If the wired and wireless clients are in the same subnet, it will likely be simpler to keep DHCP in one place for that subnet. Because each DHCP server (in this case the Windows server and the WM3400) do not know where the DHCP discovers come from (wired or wireless), they will not be able to hand out addresses to only wired or wireless clients.
-Brandon
