How to switch off LED of a single AP 7522 permanently ?
info_systemhaus
New Contributor II
I have s small private customer solution with 5x AP7522, without central Controller.
one of the AP´s is the virtual Controller.
customer demands that we switch of the LED´s on the AP´s permanently, he don´t want to have
any blinking or flashing.
As per CLI Reference there is a command .. #NO LED for Profiles.
I tried to select the AP via CLI and his mac address and set this command .. "no success"
I tried to select the builtin AP 7522 Profile and set this command "no success"
i made a "commit" and reload .. "no success"
where is my fault ?
I can not imagine, that is not possible on such a professional AP to Switch off the LED´s ...
Regards
Chris
5 REPLIES 5
RobertZ
0dec3d58da584feebf148dc1c2bf1eb9_RackMultipart20171106-108834-1o5omio-image_inline.png
RobertZ
If you prefer to use the GUI but are running the enterprise UI follow the below:
configuration --> system profile --> advanced --> miscellaneous -->LEDs --> select 'off'
Andrew_Webster
New Contributor III
The correct format for the command to disable LED via the CLI is:
If you want to disable LED on ALL APs, you need to know the name of the profile applied to the APs, default-ap7522 would be it unless you made changes:
conf profile ap7522 name-of-your-profile
no led
commit write
If you want to disable LED on a single AP:
conf ap7522 mac-address-of-AP
no led
commit write
You might need to remove overrides if you've introduced local AP configs and the profile isn't working as expected:
remove-override led
commit write
JESUS_REYES_DIA
Hello , turn off Is possible, but you should not apply over the profile, you should apply over config ap7522 Mac Device.
