How to tell if 5GHz Channel is setup in Extreme Wireless
  • Question
  • Updated 1 year ago
  • Answered
Using around 42 Extreme AP3805i with a wireless nac controller. Can't seem to find the 2.4GHz nor the 5 GHz section inside the controller. Anyone have any ideas where this is?
Photo of Bobby
Bobby
  • 210 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,024 Points 20k badge 2x thumb
The AP radio default settings are in > AP > Global > default settings.
Or per AP in AP > select the AP > radio1&2.
But I'd ask whoever installed the controller to give you a short introduction as it might be a bad idea to play around without any skills on the product.
Photo of Bobby
Bobby
Thanks. I figured as  much and they are enabled
Photo of Joshua Puusep
Joshua Puusep
  • 2,254 Points 2k badge 2x thumb
You can also look under the "AP Inventory" Report under the reports tab, which will give you data for all of the known AP's.  Under the Topology Column, Rdo "1" is the 5Ghz and  Rdo"2" is 2.4Ghz.  You can see both the Channel and Transmit powers for each radio under the Antenna Column.  The field will be blank if the radio is off.
