How to turn on radion on AP7161 Wing 5.7
  • Question
  • Updated 1 year ago
  • Answered
Hi everybody
My radio is off, how to turn it on.
Thank you!
Photo of Tuan Nguyen
Tuan Nguyen
  • 678 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
Tuan Nguyen,
Could you please check if the two-digit country code is set in the RF Domain?
The country code must be set accurately to avoid a device's illegal operation, as device radios transmit in specific channels unique to the country of operation.
Tuan Nguyen
Thank you
I chose the country and got a wifi signal, but country have only usa while my other devices have a lot of options. My mesh use country canada-ca.
Orther device
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,292 Points 4k badge 2x thumb
You also need to have a WLAN mapped to the radio.
Photo of Douglas Novell
Douglas Novell, Employee
  • 506 Points 500 badge 2x thumb
Mapping the WLAN to the radio can be done either at the AP profile or as a device override.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,528 Points 20k badge 2x thumb
If you look on the first screenshot you'd see that it's a US model.
I'm not a WiNG expert but I'd assume that a US model only supports country US.... at least that would make sense :-)
I've found that list in the install guide online...
Tuan Nguyen
Thank you
True is my product code is US, can it work reliably with systems use Ap-7161-WR
Photo of Andrew Webster
Andrew Webster
  • 1,816 Points 1k badge 2x thumb
Tuan,
The country code specifies what channel and power levels are allowed to be configured on the radios.  Using the wrong country code in your country may be illegal.  Check with your local regulatory authorities first.
As a general rule, -US product code are to used and sold solely in the USA.
