How to upgrade EWC firmware by using Inventory Manager?
Shuo_Tseng
Hi, All
I can't upgrade EWC(V2110) firmware by Inventory Manager, but i can download configuration file from EWC to NetSight.
How can i do?
8 REPLIES 8
Doug
Shuo Tseng, We will work with you via the GTAC case ticket to get this issue resolved.
Thanks,
Doug
Doug Hyde
Director, Technical Support / Extreme Networks
Shuo_Tseng
Dear Doug
I already setting.
Is an SNMP credential on the controller with the correct CLI credential assigned?
9e4a623bbbb24365a7081a5623338f96_RackMultipart20150610-30191-1h2ial6-EWC_Firmware_Upgrade_error3_inline.jpg
In Inventory Manager if you select the controller and go Tools ----> File Transfer Method does it show as using SCP?
9e4a623bbbb24365a7081a5623338f96_RackMultipart20150610-10823-1ofvijn-EWC_Firmware_Upgrade_error4_inline.jpg
If you select the device and hit the "Image Information" tab do you have "Controlled by Device Type" for the "Configuration MIB" field? Does the directory root/configs/tmp exist?
9e4a623bbbb24365a7081a5623338f96_RackMultipart20150610-8383-b96hxl-EWC_Firmware_Upgrade_error5_inline.jpg
Under Tools ---> Options ----> File Transfer settings -----> SCP Transfer Settings ----> do you have the correct login information defined?
9e4a623bbbb24365a7081a5623338f96_RackMultipart20150610-6329-1b6ystz-EWC_Firmware_Upgrade_error6_inline.jpg
Doug
Are you all set with this Shuo Tseng?
Doug Hyde
Doug
Shuo Tseng,
I will open up a case ticket and have someone reach back out to you directly. If we missed anything in the GTAC Knowledge link I will have it updated.
Thanks,
Doug
Doug Hyde
