How to Upgrade Third Party Switches Via Netsight
  • 2
  • Question
  • Updated 3 months ago
  • Answered
Hi Community,
Is it possible to upgrade third party switch firmware through Netsight?
How we can do that?
Thanks in advance!
Photo of Alex
Alex
  • 438 Points 250 badge 2x thumb
Posted 3 months ago
  • 2
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,760 Points 5k badge 2x thumb
Hi.
the answer is Yes :)
The exact procedure does depend on the Extreme Management Center (XMC) / Netsight version. In the latest version we added some more options to configure that.
In general here are steps:
1. upload the firmware file to your XMC to proper directory
2. configure XMC Profile including CLI credentials
3. configure assign the XMC profile to your 3rd party device
4. assign the firmware transfer method to the 3rd party device
5. run the firmware upgrade
What version of XMC / NetSight do you use?
Z.
Photo of Alex
Alex
Hi Z.
Thanks for your help!
Currently, we are using Netsight 6.3. Any limitations at this version?
Best Regards!
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hi Alex,
If you are using 6.3, maybe you need to use Inventory Manager.
The following article maybe could help you.
https://gtacknowledge.extremenetworks.com/articles/Solution/Inventory-Manager-Pre-and-Post-scripts
Best regards,
Photo of Alex
Alex
Thanks Bin, very helpful!
Best regards.
