How to use the Netsight to sending alarm when port without inline-power supply?
  • Question
  • Updated 3 years ago
  • Answered
The Extreme switch X440 PoE fail always without error log.
When the PoE fail, CLI "show inline-power info" will return timeout.
Can I using the Netsight to notice me that the inline-power is fail?
And how to create the alarm when the port without inline-power supply?
Photo of Chan Ching-hsiang
Chan Ching-hsiang
  • 190 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,650 Points 5k badge 2x thumb
Does Netsight receive a syslog message or a trap?
(Edited)
Photo of Dorian Perry
Dorian Perry, Employee
  • 2,302 Points 2k badge 2x thumb
Which EXOS version is running on the switch?
Chan Ching-hsiang
The X440 version is 16.1.2.14.
There is no PoE error log. So Netsight can't receive the error.
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Chan,
Could you please check if you see any messages in the log like below:
06/26/2014 20:41:01.16 <Erro:HAL.Card.Error> Slot-1: poePlusInit: Initialization failed
Slot-1 DESWMUELEO13-OG4.2 # show inline-p sl 1
Timeout occured while retrieving information from hardware.
Usually, we will have the poe plus init failure in the logs. May be this could be sent to the syslog server.
The PoE failures (Hardware and EXOS version) are similar to article:
Switch loses Power Over Ethernet until next rebooted
The recommendation is to contact GTAC for further investigation.
(Edited)
Chan Ching-hsiang
I have found that the error message "Erro:HAL.Card.Error".
And how to use the syslog to trigger netsight sending the email?
Chan Ching-hsiang
Thank you guys!
I have create the alarm with the Syslog message.
It works!
Photo of Sarah Seidl
Sarah Seidl
  • 1,356 Points 1k badge 2x thumb
Hello,
I wanted to see if we could setup this alarm too.  In the netsight (6.3) console, I go into Alarms Manager to add a new alarm for this, but I can't find how to either pick the HAL.Card.Error or enter it in manually.   I can't figure out what I'm missing.  Under the criteria tab I have the options:  by event, by selected trap, by custom criteria, by device status change, by threshold or by flow.  I can't find anything in the selected trap options, so thought custom criteria might be promising not sure.  Could anyone direct me?
Thank you,
Sarah
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,458 Points 50k badge 2x thumb
Hi Sarah,
you'd set it in the "custom criteria" section in the alarm manager.
I.e. in the below example I trigger on an Syslog event that includes the phrase "AP370".
-Ron
Sarah Seidl
Thanks Ron, I looked into that but can't seem to find a generic inline power issue phrase. We have security cameras and another brand of wireless APs (not extreme).....
We did have a power supply stop giving power this weekend and got an alert this time so maybe it's reporting..
PSU Power Status ExtremeXOS (Stack) version 15.3.1.4 v1531b4-patch1-44 by release-manager on Fri Sep 5 16:29:36 EDT 2014 number 17 status presentPowerOff(4)
