how to web manage extreme networks x460-24t switch ?
  • Question
  • Updated 3 years ago
  • Answered
what static Ip should I assign to my computer to access above switch via web browser and what URL to browse ?
Currently I telnet to it via gateway assigned for vlan 2001 and type in commands .
Photo of sumeet
sumeet
  • 798 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 6,058 Points 5k badge 2x thumb
If you can telnet then already you have the communication from the PC to the switch
You need to make sure web http is enabled in the switch.
"enable web http"
then you can just provide the VLAN 2001 ip address in a web browser to access the GUI.
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Hi Sumeet,
This article might be helpful to get you started with the configuration.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-the-web-interface
Photo of sumeet
sumeet
after I ran
enable web http
and browsed http://10.0.0.1 (not https)
I got extremeXOS screenplay login .
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-the-web-interface tells the same.
Thanks.
(Edited)
