How we do implement Stacking enable on already running production environment?
  • Question
  • Updated 4 months ago
  • Answered
Want to implement Stacking in already running the production environment, do we have required to backup of configuration or again will do VLAN port-based configuration?
Model is: X440-p24
Photo of Alok Shukla
Alok Shukla
  • 964 Points 500 badge 2x thumb
Posted 4 months ago
Alok Shukla
Suppose if we enable stack, does older configuration will removed?
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
yes, the Old configuration gets removed.
Alok,
 If you enable stacking on a stand-alone switch (which has existing configuration), the configuration wouldn't be available on the switch.
 As the stack would be booted with Factory default. You would need to re-configure stack once again (i.e the port related configuration and vlan configuration,
 everything from the scratch.
Alok Shukla
  • 944 Points 500 badge 2x thumb
Does manual mac-address is beneficial for stack implementation.
Photo of David Coglianese
David Coglianese, Embassador
  • 7,368 Points 5k badge 2x thumb
You should be able to pull the config off, change the port syntax , create the stack, and drop the config back in with about a 15 minute outage.
If possible I would test the updated config on a lab switch, just to be safe.
Good luck,
Photo of Chad
Chad
  • 160 Points 100 badge 2x thumb
Just a quick note to say that... I hope this changes in the future. This function should be automatically done, when a stack is enabled, config would be updated transparently, and user shouldn't worry about it. It was a big surprise when I found this out going from ERS to EXOS.
I find myself now enabling stacking on all my switches, even if they are one unit installs just to be future proof. my switches are remote, and we sometimes decide to add units when more ports needed.
Thanks,
Photo of Ansley Barnes
Ansley Barnes
  • 64 Points
I actually was very surprised when I reconfigured an X440-G2-24p running EXOS 22.4 from a non-stacking config to a stacking one that the config was preserved and converted to a stacking configuration. I assume it wouldn't be appropriate in all circumstances, but in the basic situation where the standalone switch you had will now be a stack master, it now works. I was prepared to dump an already-prepared config I had onto the unit but did not need to.
