How do I configure ingress and egress rate-limiting traffic?
  • Question
  • Updated 5 years ago
Create Date: Mar 3 2013 10:00AM
I found this solution and I believe it is worth sharing:
How to set the rate-limit on egress and ingress port?
Platform: Summit X450, X450a, and X450e, X460, X650, X440, X670, X350, X150, X480 and most BD8k platforms
Version: All EXOS
To set 20 M ingress and egress traffic from port 1
Create vlan test
Configure test tag 10
Configure test add po 1
Configure test ipa 10.10.10.1/24
Create vlan v2
Configure v2 tag 20
Configure v2 add po 2
Configure v2 ipa 20.20.20.1/24
ena ipf
Ixia------------------port (2) x450port (1) ----------------ixia
Set Ixia to send both way line rate traffic.
For  Egress rate limit
Configure ports 1 rate-limit egress 20 Mbps  => this will rate limit the egress traffic from port 1 to 20 M (doesn’t matter where this traffic is coming from)
Sh port 1, 2 utilization
Link Utilization Averages                            Thu Oct 2 22:46:10 2008
Port     Link    Link   Receive       Peak Rx      Transmit     Peak Transmit
         Status Speed % bandwidth   % bandwidth % bandwidth % bandwidth
1         A       1000    100.00        100.00          2.00            100.00
2         A       1000    100.00        100.00          100.00          100.00
Note: remember 20 Mbps for 1 gig port is 2%
For ingress rate limit
For all Broadcom platforms, we have to create a meter and link it to a policy for ingress rate limit,
Here are the steps to do that,
1.     create and configure a meter
2.    create a policy file and link this meter to that policy file
3.    Now apply the policy to the ingress port.
Step-1 creates and configures a meter
Create meter meter-TEST1
Configure meter meter-TEST1 committed-rate 20 Mbps out-actions drop
Step-2 create a policy file and link this meter to that policy file
Edit policy blnmtlb2swe_TEST1.pol
   entry rule1
    if match all {
    then
      meter meter-TEST1;
Check policy blnmtlb2swe_TEST1
Configure access-list blnmtlb2swe_TEST1 ports 1 ingress  => this will rate limit all the  ingress  traffic coming from port 1 to 20 M (doesn’t matter where this traffic is egressing)
2         A       1000    100.00        100.00          2.00          100.00
Note: We have to remember that we configure the rate-limit on ingress port, but we can see the output on egress port (port 2)
(from ethernet)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Mar 4 2013 5:35PM
I actually figured out how to do the same thing and was going to post to see if there is a better way to do it.
A need has arisen for us to limit ingress and egress bandwidth on one specific port on one specific switch.
It seems a bit messy, using a QOS setting for egress traffic, and ACL for ingress...
If anyone know of a better way to accomplish this please share.
(from mjurewicz-ci)
Create Date: Mar 5 2013 2:47PM
That is actually the way to configure rate-limiting as far as I can tell. And it is not really that messy.
Keep in mind that all you need to do is:
Configure ports 1 rate-limit egress 20 Mbps <== for egress (one step)
and for ingress (4 steps)
   entry rule1
    if match all {
    then
      meter meter-TEST1;
(from ethernet)
Create Date: Mar 5 2013 3:33PM
I see, for some reason I was using that AND a QOS setting
Thank you for clarifying this
Just saying its "messy" since it cannot be accomplished with just the ACL, or just the rate limit setting
Can you explain what the "out-actions" setting will do for the meter?
(from mjurewicz-ci)
Create Date: Mar 6 2013 5:50PM
You are right. Those are not straightforward commands.
To answer your question, I would point you to this portion of the command reference guide. It contains all the parameters in this command.
https://www.extremenetworks.com/libra...
(from ethernet)
