How much memory are the Summit 460-48t and the 460-24t switches supposed to have?
  • Question
  • Updated 4 years ago
I've got 460-24t switches claiming they have 1gb of RAM, and 460-48t claiming they have 512mb. Is this normal, and if so, why do the "bigger" switches have less RAM?
I can't find an official spec sheet anywhere that lists the RAM.
Photo of Dave E Martin
Dave E Martin
  • 272 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Dave
The memory should be 1G total based on the DS and it should be the same on each one.
If you do a show memory on each switch can you post the results here.
Thanks
P
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
Yes. The storage memory should be 1 GB for all X460 switch.
What I am thinking is that X460-48 switch may have 2 ASIC chip. First 24 ports are assigned to first ASIC and next 24 ports are assigned to 2nd ASIC.
First ASIC might gets 512 MB and 2nd ASIC would get 512 MB. However, total memory would be 1 GB. However, I have to confirm it if 48 port switch does have two ASIC or not.
Total memory is shared amongs the ASIC. It's using smart memory allocation method.
(Edited)
Dave E Martin
System Type:      X460-24t
System Memory Information
 Total DRAM (KB): 1048576
System Type:      X460-48t
 Total DRAM (KB): 524288
Sumit Tokle, Alum
Interesting: For me it's shows below output. What software is running on switch? How many 48 port device you have?
SysName:          X460-48tSysLocation:
SysContact:       support@extremenetworks.com, +1 888 257 3000
System MAC:       00:04:96:51:E8:6E
* X460-48t.2 # show memory
 System     (KB): 18152
 User       (KB): 168996
 Free       (KB): 861428
Dave E Martin
I'm not sure how many we have off-hand (I'm not at work right now), but of the two 48t's I've checked, one is 15.3.3.5 p1-3 and the other one is 15.5.1.6
(Edited)
Photo of Stephane Grosjean
Stephane Grosjean
  • 762 Points 500 badge 2x thumb
You should have 1GB of RAM on any x460.
I would recommend you to open a case with GTAC to investiguate further why your (some?) 48 ports report 512MB.
Do I understand correctly that you are saying that at least 2 x460-48 are having the same issue, and they are running different EXOS version?
Dave E Martin
yes
