How to Copy a SecureStack Configuration between DRAM and Flash
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 5533
Products
SecureStack C3
SecureStack C2
SecureStack B3
SecureStack B2
SecureStack A2
Commands
'show config outfile'
'configure'
Goals
Save configuration to Internal Directory
Restart using a new configuration
Copy a config
Solution
To save a copy of the running configuration from DRAM to the internal File Directory (Flash) for archival purposes, write it to the 'configs' directory
  C2(rw)->show config outfile configs/myfile.cfg
C2(rw)->dir
Files: Size
configs:
myfile.cfg 7269
logs:
current.log 48401
C2(rw)->
To restart the system using this configuration, reference it in the 'configs' directory:
  C2(rw)->configure configs/myfile.cfg
This command will reset the system and clear current configuration.
Are you sure you want to continue (y/n) [n]?y
Copy OK: 7269 bytes copied
For more about these command sets, please refer to the SecureStack Configuration Guide for your product.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
