How to debug an OSPF adjacency problem?
  • Question
  • Updated 4 years ago
  • Answered
I have a Summit 670V switch with a /30 uplink to a Cisco router.  OSPF is configured but a neighbor adjacency is not being formed.  I am using MD5 authentication with a key on both sides of the link.
I'm familiar with using Cisco's debug commands but not Extreme's.  On a Cisco device I would turn on 'debug ip ospf adjacency'.  If I was limited to troubleshooting this OSPF adjacency problem on the Summit switch, would I be able to use similar debugging tools to do that?
Photo of Jim Keeffe
Jim Keeffe
  • 390 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hey Jim
There is a debug for OSPF however I would recommend contacting TAC to have them help you get the info and look at it. Depending on the Debug command the CPU can spike high.
P
Photo of Jim Keeffe
Jim Keeffe
Hi Paul -
After enabling 'enable log debug-mode' I see only one debug OSPF command, which only displays license information:
* VoIP-MDF-Extreme_V670.2 # debug ospf ?
  show            Show
* VoIP-MDF-Extreme_V670.2 # debug ospf show ?
  epm             Display licence information from epm
* VoIP-MDF-Extreme_V670.2 # debug ospf show epm
Effective license: 2
Switch license:    2
Features:    edgemode,
* VoIP-MDF-Extreme_V670.3 #
Is there another debug mode that one uses?  Also, I have a Summit 670V in a lab so I don't care about CPU spikes at this point.  I'd hate to have to contact TAC just to be able to do some simple debugging,
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
configure log filter "DefaultFilter" add events ospf.event severity debug-summaryconfigure log filter "DefaultFilter" add events ospf.neighbor severity debug-summary
configure log filter "DefaultFilter" add events "ospf.hello.PktInv"
configure log filter "DefaultFilter" add events "ospf.lsa.PktInv
configure log filter "DefaultFilter" add events "ospf.lsa.LSUpdtPktInv"
configure log filter "DefaultFilter" add events "ospf.lsa.DropLenInv"
configure log filter "DefaultFilter" add events "ospf.lsa.CksumInv"
With the above log filters we can troubleshoot any kind of ospf issues.
If it is just Ospf Hello
And TCPdump will show Hello Sent and received.
TCPDUMP can be taken only from debug mode which needs debug password.
Extreme TAC can Help on this.
Photo of Jim Keeffe
Jim Keeffe
Thank you! - I'll give this a try.
(Edited)
Photo of Jim Keeffe
Jim Keeffe
Two last questions.
1.  Once I configure the above log filter (or any other filter for that matter) do I view the log entries with 'sh log'?
2.  Is there a way to have the log entries display in real-time on the console screen?
Thanks again.
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
X440-24t.2 # enable log target
  console           Serial port console target
  memory-buffer     Internal memory target
  nvram             Non-volatile memory buffer target
  session           Current CLI session target
  syslog            Remote syslog target
  upm               Sending messages to UPM as events
  xml-notification  Sending messages to xml notification target(s) as events
Photo of Jim Keeffe
Jim Keeffe
Thanks! have a great day.
