How to deploy FlexViews without a restart of Netsight ?
  • Question
  • Updated 3 years ago
  • Answered
I've learned that I'd share my FlexViews with my other Netisght users by uploading the files to the
/usr/local/Enterasys_Networks/NetSight/appdata/System/FlexViews/My
FlexViews/
directory of Netsight.
The problem is that I'd need to restart Netsight to force the update to every client.
Is there a other way to deploy it without a restart as a reboot of Netsight isn't very practical.
Netsight version 6.1.0.121 early build
Thanks,
Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
Posted 4 years ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,474 Points 5k badge 2x thumb
You can upload the flexview and mib files to your client. Than you do not need NetSight server restart.
on my computer running windows = C:\Users\zpala\AppData\Roaming\NetSight\System\FlexViews
(Edited)
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
Are saying to send the flexview to the other people you want to be able to use the flexview? The mibs are on the NetSight server, so anyone could access those.... Correct?
Correct. You can put the flexview on client and restart the client. Then you can use it in console. If you want to use the flexview in OneView, then it needs to be on server.
That is an interesting work around if restarting the server is an issue. My issue is that the FlexView displays but the fields do not populate. Any ideas?
The mibs were loaded onto the server and the server was restarted. Anyone is able to to see the data through console but noone is able to see through OneView.
Thanks
I saw this behavior in version 6.2 with mibs from mymibs directory. I was not able to replicate this with 6.3.0.162
It seems to me as fixed bug. It works in 6.3.0.162 in my case.
Z.
We are running 6.3.0.162.
Any other thoughts?
