how to enable gvrp? missing command gvrp
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Need to configure x440 to listen/create dynamic vlans from core switch (dell)
Photo of Gene Fontanilla
Gene Fontanilla
  • 504 Points 500 badge 2x thumb
  • indifferent
Posted 4 years ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 3,180 Points 3k badge 2x thumb
Gene,
GVRP is not supported in EXOS.
Regards
Ron
Photo of Magafox
Magafox
  • 60 Points
Is GVRP on the road map to be included in EXOS at any point ?
Regards
Terry
Photo of Mrxlazuardin
Mrxlazuardin
  • 1,534 Points 1k badge 2x thumb
Any update of GVRP features? This feature is very helpful on other products.
Gene Fontanilla
i think GVRP is replaced by MVR on EXOS
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
Hello Gene,
GVRP is a GARP application that provides 802.1Q-compliant VLAN pruning and dynamic VLAN creation on 802.1Q trunk ports.
With GVRP, the switch can exchange VLAN configuration information with other GVRP switches, prune unnecessary broadcast and unknown unicast traffic, and dynamically create and manage VLANs on switches that are connected through 802.1Q trunk ports.
In EXOS:You must be in 15.3.2
Multiple Registration Protocol/Multiple VLAN Registration Protocol is used for dynamically creating
VLANs and/or dynamically adding ports to VLANs. As per IEEE Std 802.1Q-2011, some VLANs can be
marked as forbidden VLANs on some ports so that when MVRP PDU is received on the port with the
particular forbidden VLAN Id, the VLAN is not created and if the VLAN is already there, the port is not
added to the VLAN.
The VLAN registration is of three types:
• Forbidden—Port is forbidden to be added to the VLAN
• Normal—Port is allowed to be added to the VLAN
• Fixed—Port is statically added to the VLAN
Gene Fontanilla
Hi Parthiban! thanks for the reply, we decided to replace the dell switch with a new x670v switch, making it easier to use MVR
Mrxlazuardin
Hi Parthiban,
How about compatibility between GVRP capable switch with MVR on EXOS? Our existing devices are not MVR capable.
Best regards,
