how to filter bpdu frames
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Jul 6 2012 4:24AM
I'm desperately trying to make xos switches drop bpdu. I'm not using STP , but I have have some old no-extreme switches that keep broadcast bpdu. Since my network is huge, I need that XOS switches drop those bpdus.
I've managed to do that on cisco and almost any other switch with cisco-like CLI
Is there someway to do that on XOS?
(from Stefano_Ferrari)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Jul 6 2012 9:02AM
following concept guide:
Dynamic ACL for STP
create access-list bpdu1 "ethernet-destination-address 01:80:C2:00:00:00;" "deny; count bpdu1"
conf access-list add "bpdu1" first ports 6 ingress
To configure a dynamic ACL for blocking PVST frames on port 6, use the following:
create access-list bpdu2 "ethernet-destination-address 01:00:0c:cc:cc:cd;" "deny; count bpdu2"
conf access-list add "bpdu2" first ports 6 ingress
Jarek
(from Jaroslaw_Kasjaniuk)
Photo of Suleima
Suleima
  • 70 Points
Is this a valid answer? Please confirm.Thanks.
Photo of Ron Huygens
Ron Huygens, Employee
  • 2,928 Points 2k badge 2x thumb
Hi Suleima,
Yes, this is a valid answer. In fact it is copied out of our concepts guide.
Thanks,
Ron
Photo of Suleima
Suleima
  • 70 Points
Hi Ron,
Actually am very new to Extreme..
For Vlan7 -  ZU1 and port 4, Need to config bdpu filter enable ( Like Cisco). The STP functionality is not required (listening, learning, disabled). Would you please comment how to proceed on that and what would be the command?
Thanks!
Suleima
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
By default, switch will drop the BPDU packet if STP is not configured on the switch and switch will generate the EMS log messages  with "STP.InBPDU.Drop". However, you can configure the above dynamic ACL to block the BPDU traffic coming on port. Refer the ACL chapter from EXOS concept guide for sample configuration.
