How to get the possible port range on a switch within a script?
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Jun 22 2012 2:04AM
Hi!
I want to write a script for Ridgeline that enables 802.1x on all ports that have MAC authentication enabled. The problem now is that I've following x450e setups:
  • 24 Port
  • 48 Port
  • 48 + 24 Port (stacked)
  • 48 + 48 Port (stacked)
Whats the best way to get the port range used on this stack/switch so I can execute for example:
enable netlogin ports 1:1-48, 2:1-24 dot1x
Thx for your help.
(from Robert_Penz)
Photo of EtherNation User
EtherNation User, Official Rep
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Aug 3 2012 6:11AM
I would have a script parse through a "show config netlogin" command and grab all the ports with the "enable netlogin <port> port mac". Once the ports are added to a list, then they can easily be added to a "enable netlogin ports <port> dot1x" command.
(from john_padilla)
