How to preserve Changes in a Topology Map
  • Problem
  • Updated 5 years ago
  • Solved
When i create a map with imagens,i close it and i open my imagen are distorted even saving frame by frame, what can i do to preserve my changes.
Photo of Isis Cobos
Isis Cobos
  • 90 Points 75 badge 2x thumb
Posted 5 years ago
Photo of Tyler Marcotte
Tyler Marcotte, Official Rep
  • 2,740 Points 2k badge 2x thumb
Hi Isis,
Could you give some more details on what's going on? I just tried setting a background image and it came back up just fine. Are you using background images? Also what format are they? What version of NetSight are you running?
Thanks,
-Tyler
Photo of Isis Cobos
Isis Cobos
The imagen are in jpeg format, the version is 4.3.0.106, i put it as background mm but it doesnt keep changes.
Hmm.. I just tried this with a jpeg image on 4.3.0.108. I'm not seeing any problems after saving it and reopening it. I would suggest opening a case with GTAC to see if they can help troubleshoot your problem.
Photo of Isis Cobos
Isis Cobos
ok thanks so much tyler, another doubt, do you know how can i copy a map a mean the format the header or if it is possible?
Photo of Tamera Rousseau-Vesta
Tamera Rousseau-Vesta, Extreme Alumna
  • 2,760 Points 2k badge 2x thumb
Isis, do you have any additional questions regarding your question about Topology Maps?  If so, please let us know!  Thank you!
Sorry Isis, I don't think I fully understand your question. Are you trying to duplicate a topology map?
