How to Prioritize traffic based on DSCP marking, on SecureStacks
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 7589
Products
SecureStack C3
SecureStack C2
SecureStack B3
SecureStack B2
Protocols/Features
Policy
VoIP
DSCP
CoS
Goals
Prioritize incoming traffic based on DSCP marking
Sample configuration
Cause
This SecureStack policy configuration will, for all ports, prioritize incoming frames - VLAN-tagged or not - which have DSCP value 46 or 48 (5811).
Note1: In the applied network, those values are used by the routers to identify Voice over IP traffic. This will not be true of all networks.
Note2: SecureStack B3 and B2 units will require a Policy License (5781) before this configuration may be applied to them.
Solution
set policy profile 1 name VoIP
set policy port *.*.* 1
set policy rule 1 iptos 176 mask 6 cos 5
set policy rule 1 iptos 184 mask 6 cos 5
By default the outgoing prioritized (priority 5) frames will hit transmit queue#4, while non-prioritized (priority 0) traffic will hit transmit queue#1.
Queue#1 by default receives no service if anything is waiting in queue#4 ('show port txq').
If outgoing frames are VLAN-tagged, the tag of affected frames will carry a Priority of 5.
The specific rules you use will depend upon which bits of the TOS byte you wish to examine:
    If you want DSCP values 44 and 46 and don't care about the remaining two TOS bits:
       set policy rule 1 iptos 176 mask 6 cos 5   [= TOS bits 101100xx]
set policy rule 1 iptos 184 mask 6 cos 5 [= TOS bits 101110xx]
    If you want DSCP values 44 and 46 and want to ensure that the remaining two TOS bits are zero:
       set policy rule 1 iptos 176 mask 8 cos 5   [= TOS bits 10110000]
set policy rule 1 iptos 184 mask 8 cos 5 [= TOS bits 10111000]
    If you want TOS values 44 and 46:
       set policy rule 1 iptos 46 mask 8 cos 5    [= TOS bits 00101100]
set policy rule 1 iptos 48 mask 8 cos 5 [= TOS bits 00101110]
Please contact Enterasys Networks Technical Services for further assistance, as necessary.
Photo of FAQ User
FAQ User, Official Rep
  • 13,620 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
