How to reset wm3600
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Lost admin password to w3600. Need to know how to perform complete factory reset.
Photo of Berkey
Berkey
  • 92 Points 75 badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hey Mike
to reset a WM type in reset into the login and FactoryDefault in password.  Note case sensitive.
Thanks
P
Photo of Drew C.
Drew C., Community Manager
  • 39,302 Points 20k badge 2x thumb
Hi OP,
Welcome to The Hub!  Can you please create a new conversation and share with us a screenshot of the output you're seeing?
Also, let us know what version the controller is running.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,304 Points 10k badge 2x thumb
Hi OP,
I agree with Drew, it would be best to create a new conversation for this with a screenshot of the output.
However, taking a bit of a shot in the dark, is the baud rate set correctly? The WM3600's console port runs at 19200 baud, and most PuTTY and most other terminal emulators default to 9600 baud. A baud rate mismatch could lead to garbled text being seen.
-Brandon
Photo of OP Gupta
OP Gupta
  • 80 Points 75 badge 2x thumb
snapshot of garbage seen under hyper terminal
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
If you are connected to a WM3400/3600/3700 the serial port needs to be configured for 19200 baud... Sounds like you are trying 9600?
Photo of OP Gupta
OP Gupta
it is connected at 19200
