HP Comware based switches and Identifi Wireless issue
  • Question
  • Updated 3 years ago
  • Answered
I am looking for a little help getting our Identifi Wireless working with HP Comware based switches.  We currently have older Hp Procurve switches that work just fine but the newer HP switches are running Comware.  I have provisied the port just as I would on the Procurve.  We leave the Management vlan untagged and the user vlans tagged.
We have it as such now on the Procurve.
vlan 12 mgmt untagged
vlan 102 staff tagged
vlan 104 apple tagged
vlan 108 android tagged
vlan 112 laptop tagged
vlan 116 gaming tagged
I have all the vlans setup exactly the same on the Comware switches.
I have tried using both Hybrid and Trunk ports and neither will allow the access point to communicate with the wireless controller.
Does anyone have any ideas on what I could do.
Photo of Steve Krasinski
Steve Krasinski
  • 100 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Andre Brits Kannemeyer
  • 5,214 Points 5k badge 2x thumb
Hi Steve
I presume that vlan 12 (Management) is the vlan that the AP uses to discover the Controller
Can you give me the port config on the comware device?
The port should be configured as a trunk port allowing vlan 102,104,108,112 and 116.
Then you will have to ensure that the native vlan (Untagged) is configured for vlan 12.
That shoudl replicate the config from the procurve.
Steve Krasinski
                            PVID           VLAN Passing
GE2/0/32              12          102, 104, 108, 112, 116
This is what it is setup in the Comware config. I have this port configured as a trunk port at the moment.
VLAN 12 is the Management VLAN that talk to our controllers.
(Edited)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
Could you please provide the exact model name of the switch.
-Ron
Steve Krasinski
HP 5130-48G-PoE+-4SFP+ (370W) EI JG937A
Looks like a old Huawei CLI command set.
Please add "port trunk permit vlan 12" to the port config and try it again.
-Ron
Steve Krasinski
Ron,
That worked,  Thank you very much.  I have been beating my head off a wall trying to figure this out.
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
So as I understand your AP's are in VLAN 12 (untagged) right? Do you want AP communicate on the same VLAN with Wireless Controller ? If so , which controller port is in this VLAN?
No problem, I am glad I was able to help.
Wish u a great day.
Just as a reference if someone is looking for an example in the future - I assume the config looks now like this ....
interface Ethernet1/0/48
 port link-type trunk
 port trunk pvid vlan 12
 port trunk permit vlan 12,102,104,108,112,1161
Photo of Jason
Jason, Employee
  • 3,608 Points 3k badge 2x thumb
Ron,
Thank you for sharing your knowledge! That's a great example what The Hub was intended for when it was started.
I have created a knowledge article to document this particular situation and resolution - https://gtacknowledge.extremenetworks.com/articles/Solution/Access-Points-not-communicating-with-Ide...
Let us know if that looks accurate or needs further editing, etc.
Thanks again,
Jason (and the GTAC)
Hi Jason,
could you please edit the symptoms to "can't ping" :-)
Thanks,
Ron
Photo of Jason
Jason, Employee
Ron,
Done.   Thanks! Got that confused with another issue :-)
- Jason
