Hybrid QSFP28 Breakout
  • Question
  • Updated 1 year ago
  • Doesn't Need an Answer
I know one 100Gbps QSFP28 can be splitted to 4 25Gbps SFP28 or 2 50Gbps QSFP28 using breakout cable. Is it possible to have both type splitting? What if one or more but not all of them should go to fiber, what item should I use for that?
Best regards,
Photo of Mrxlazuardin
Mrxlazuardin
  • 1,534 Points 1k badge 2x thumb
Posted 1 year ago
Photo of OscarK
OscarK, ESE
  • 7,792 Points 5k badge 2x thumb
No, not that I know of, you configure the whole port to a certain partitioning, so either 4x25 or 2x50 but you cannot partition to 2x25 + 1 x50.
Mrxlazuardin
Hi Oscar,
Is it possible to have some DACs and some optics with same speed?
Best regards,
Photo of OscarK
OscarK, ESE
I think there is no cable that splits 1 connector to partly passive copper and the other half to active copper.
Mrxlazuardin
Hi Oscar,
Do you know SFP28 converter for converting SFP28 partition to 25Gbps optic?
Best regards,
Photo of OscarK
OscarK, ESE
I think you need this MPO module.
10331 CFP2 100GBASE- SR10 100 Gigabit Ethernet-SR10 CPF2 optical module, MPO connector, 100m link length
Mrxlazuardin
Hi Oscar,
How can I get some SFP28 optics and some SFP28 DAC with that module?
Best regards,
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,850 Points 10k badge 2x thumb
If you plan to have out of a QSFP28 some 25Gbps lanes as regular fiber to plug into a transceiver (SFP28) and some as passive copper DAC, that doesn't exist (to my knowledge).
Either you plug a QSFP28 DAC/AOC that breakout into 4xSFP28 of the same type, or you use a QSFP28 transceiver (SR4 for example) and you use a breakout cable MPO-to-8xLC, to connect to other transceivers (SFP28).
Mrxlazuardin
Hi Oscar,
It seem that what I'm looking is a kind of media converter but with SFP28 to SFP28 or at least SFP28 to SFP+. With that media converter, I can plug a partition of breakout cable on one port and plug a transceiver on other port. It is like https://www.omnitron-systems.com/iconverter-xg-10g-fiber-to-fiber-industrial-media-converter.php but this media converter is for SFP+/XFP. Any suggested one which match my requirement?
Best regards,
