Hyper-V V2110 VM Live Migration problems
  • Problem
  • Updated 10 months ago
  • Solved
Hello, everybody,
I have V2110 installation under Hyper-V, everything works fine instead of backup and migration operations.
I suppose that there is a snapshot problem, but it's only my guess.
Sometimes I get the following error message (attachment).
Is it possible to backup and transfer the Hyper-V V2110 VM using hypersivor tools?
Many thanks in advance,
Ilya
Photo of Ilya Semenov
Ilya Semenov
  • 4,610 Points 4k badge 2x thumb
Posted 10 months ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,502 Points 20k badge 2x thumb
Just save off a copy of the controller config and install a clean instance of hyper-v, then you can load back in the controller config....
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-save-and-back-up-a-config-file-on-t...
Ilya Semenov
Thanks, Doug!
I'll do it on Monday and share a result.
Thnx
Photo of Doug Hyde
no problem, good luck!
