I am beginning to see this error more and more on my 460G2 switches running 16.1.3.6 does anyone know what this is referencing?
  • Question
  • Updated 1 year ago
  • Answered
  • (Edited)
I am only posting this question as I do not see an actual issue so far, but do not want one to creep up and bite me. Thanks
Photo of Dean Ferraro
Dean Ferraro
  • 712 Points 500 badge 2x thumb
Posted 2 years ago
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
What error are you referring too?
Dean Ferraro
IdMgr: Current memory usage 460 Kbytes, 90 percent of 512 Kbytes. No new Identities shall be added to the database.
I also just noticed, after upgrading some switches to 16.2.1.6 that I also receive the same message. Thanks
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hello Dean,
This type of message is associated with Identity Management feature.
Please, enter the command "configure identity-management database memory-size <Kbytes>" to adjust its size. The valid range is 64 - 49152 Kbytes.
For you case, I think you could triplicate the current size (to 1536Kb).
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
Hey Dean,
Coming to this reported log error message, please find below the meaning and remedy for the same:
They are logged when the size of Identity database reaches near to max size configured. Before adding any new information in identity management, check for memory availability is performed. If 90% of the maximum allocated memory is already used and new information is to be added to the database, then these will be generated. This can be an indicator of error condition as too many identities have been discovered on the device
Remedy:
This message is for error notification purpose, and indicates that too many users/device have been detected on the device. Admin may want to check the reason for the discovery of so many identities on the device. Also, admin may want to check the configured memory size for identity database and increase the memory size, if required.
Hope the above posted conversation helps you in resolving your queries. Going forward if you need any further explanation or clarification then do let us know.
Wishing you happy new year 2017 in advance........
It is understood here the query raised  by you satisfying the answer you were looking for hence let us close this Hub thread here. Looking forward for more if needed in the future......
