I am facing some issues to configure my DemoKit LAB.
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
I am facing some issues to configure my DemoKit LAB, I have downloaded new VM images and put on my cube. I have done LAB step by step as DemoKit documentation recommendation. Please guide me how to troubleshoot this issue.
Photo of Sikander Shah
Sikander Shah
  • 712 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,442 Points 5k badge 2x thumb
Hi. Please try to contact the demokit team. If you have demokit, then you should know the email address for the demokit support. I believe you will get answer from demokit support team much more precise and accurate comparing answer from public community. Good luck.
Sikander Shah
Thank you
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
Your laptop is 192.168.10.x, can you ping from laptop to EWC1,EWC2 and DemoGW (192.168.10.1)? If yes, please check the routing table on the DemoGW (netstat -rn)
