I can download firmware EOS successfully, but not EXOS firmware.
  • Question
  • Updated 2 years ago
  • Answered
To try authentication informs that login or password is incorrect. See screen print.
Photo of Helio Jose Erhardt
Helio Jose Erhardt
  • 460 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Helio, please take a look in the article below:
How to create an extranet account
You can also click in "Request Web Login" and fill the form. Or even click in "Forgot Your Password" just in case you already have the access credentials.
Helio Jose Erhardt
Hi Henrique,
I have login, and password is no problem, so I can authenticate me and make EOS firmware download.
Thanks
Photo of George, Chris
George, Chris, Employee
  • 982 Points 500 badge 2x thumb
Hello Helio,
I checked with our IT department it is looks like there was something wrong with your account. They just corrected it.  Please logout completely, closing all broswer windows.  Attempt to log back in but please go to the Extranet first (attempt to get to an EOS page first), then go to the EXOS pages.  If it doesn't work after that, let us know.
Helio Jose Erhardt
Hi George,
Perform the steps according to your post, but it does not work.
How do I delete the login?
After adding to see if that resolves the problem.
Thanks
Would it be ok to reset your password, that way we can test things, get it working and let you know once its fixed?
I just ended up opening a GTAC case for you so we can track it accordingly.
Helio Jose Erhardt
Hi George,
Reset password and access is OK to download EXOS firmware.
Thank you so much.
