i have more messages related to LACP , Add port 1 to aggregator
  • Problem
  • Updated 4 years ago
i have more messages related to LACP  , i need to know what are those messages and are impact the sirvice
09/07/2014 08:56:04.17 <Info:LACP.AddPortToAggr> Add port 1 to aggregator
09/07/2014 08:55:56.14 <Info:LACP.AddPortToAggr> Add port 6 to aggregator
09/07/2014 08:55:54.58 <Info:LACP.AddPortToAggr> Add port 12 to aggregator
09/07/2014 08:55:51.57 <Info:LACP.AddPortToAggr> Add port 2 to aggregator
09/07/2014 08:55:51.40 <Info:LACP.AddPortToAggr> Add port 13 to aggregator
09/07/2014 08:55:41.77 <Info:LACP.AddPortToAggr> Add port 5 to aggregator
09/07/2014 08:53:26.07 <Info:LACP.RemPortFromAggr> Remove port 6 from aggregator
09/07/2014 08:53:24.52 <Info:LACP.RemPortFromAggr> Remove port 12 from aggregator
09/07/2014 08:53:21.52 <Info:LACP.RemPortFromAggr> Remove port 13 from aggregator
09/07/2014 08:53:19.52 <Info:LACP.RemPortFromAggr> Remove port 2 from aggregator
09/07/2014 08:53:09.53 <Info:LACP.RemPortFromAggr> Remove port 5 from aggregator
09/07/2014 08:53:04.24 <Info:LACP.RemPortFromAggr> Remove port 1 from aggregator
Photo of hasan issa
hasan issa
  • 154 Points 100 badge 2x thumb
Posted 4 years ago
Photo of rbrt_weiler
rbrt_weiler
  • 834 Points 500 badge 2x thumb
Those messages just inform you that some ports were removed or added to a specific LACP group. To find out which one, do a "show sharing" and look for the port association.
Whether this means an impact to your service or not completely depends on your setup. Usually LACP is used to build redundancy, so it should not affect your service in a noticeable manner.
Side note: For LACP it is recommended to use 2, 4, 8 or 16 ports in one group.
Photo of hasan issa
hasan issa
thanks for your supoort , but in my case all ports were removed and added in the same time . i already checked the link between the LACP group and evry things were OK .
