I lost the port management after upgrade
  • Question
  • Updated 2 years ago
  • Answered
I upgrade the SW to version 15.3.4.6 but i lost the port to management
Photo of Mario Recinos
Mario Recinos
  • 110 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 3,310 Points 3k badge 2x thumb
Hi Mario,
Couple of questions:
Is this on the management ethernet port or the console port?
What platform is this on?
What was the previous version?
Mario Recinos
Hi the version is 12.3.1.2 v1231b2  and upgrade  to 15.3.4 patch 1-5 and the port is ethernet port
I suggest that you connect to the serial console and look if there is still an IP address configured on the vlan "mgmt".
Is the management port "up"?
What does "show vlan mgmt" tells you?
In case the mgmt port stays down, I suspect that you run into an issue described in the following Knowledge article:
https://gtacknowledge.extremenetworks.com/articles/Solution/MGMT-port-stays-down-after-upgrade
An upgrade to any version higher then 15.3.5.1will solve this permanently.
Workaround:
Enable Auto Negotiation setting on the peer switch as interim solution.
Mario Recinos
Ok I will be check thank you
Mario Recinos
Ron
Helllo I send the output from
Slot-2 SAPCA_CC_701.24 # show iproute vr "VR-Mgmt" Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
 s   10.160.74.0/24     10.161.100.254  1    -G---S-um---- Mgmt       11d:2h:33m:8s
 s   10.161.9.0/24      10.161.100.254  1    -G---S-um---- Mgmt       11d:2h:33m:8s
 s   10.161.99.0/24     10.161.100.254  1    -G---S-um---- Mgmt       11d:2h:33m:8s
 d   10.161.100.0/24    10.161.100.202  1    -------um---- Mgmt       11d:2h:33m:10s
 s   172.16.0.20/32     10.161.100.254  1    -G---S-um---- Mgmt       11d:2h:33m:8s
 s   172.21.100.0/24    10.161.100.254  1    -G---S-um---- Mgmt       11d:2h:33m:8s
Origin(Ori): (b) BlackHole, (be) EBGP, (bg) BGP, (bi) IBGP, (bo) BOOTP,
       (ct) CBT, (d) Direct, (df) DownIF, (dv) DVMRP, (e1) ISISL1Ext,
       (e2) ISISL2Ext, (h) Hardcoded, (i) ICMP, (i1) ISISL1 (i2) ISISL2,
       (is) ISIS, (mb) MBGP, (mbe) MBGPExt, (mbi) MBGPInter, (mp) MPLS Lsp,
       (mo) MOSPF (o) OSPF, (o1) OSPFExt1, (o2) OSPFExt2,
       (oa) OSPFIntra, (oe) OSPFAsExt, (or) OSPFInter, (pd) PIM-DM, (ps) PIM-SM,
       (r) RIP, (ra) RtAdvrt, (s) Static, (sv) SLB_VIP, (un) UnKnown,
       (*) Preferred unicast route (@) Preferred multicast route,
       (#) Preferred unicast and multicast route.
Flags: (b) BFD protection requested, (B) BlackHole, (c) Compressed, (D) Dynamic,
       (f) Provided to FIB, (G) Gateway, (H) Host Route, (l) Calculated LDP LSP,
       (L) Matching LDP LSP, (m) Multicast, (p) BFD protection active, (P) LPM-routing,
       (R) Modified, (s) Static LSP, (S) Static, (t) Calculated RSVP-TE LSP,
       (T) Matching RSVP-TE LSP, (u) Unicast, (U) Up, (3) L3VPN Route
Please tell me what is (UM) and tell me if you  think need to upgrade
In this overview we can learn from the "Flags" that the link is down.
 -G---S-um----
This means:
the route is a Gateway route (G)
the route is Static (S)
the route is used for Unicast and Multicast (um)
Note that we don't see the Capital (U), that indicates the route is down, most likely caused by the mgmt port being down.
Mario Recinos
Ron
tell me if you  think need to upgrade to resolver the issue
Mario,
As I mentioned earlier:
Workaround:
