I need know serial number the license in the switches extreme
  • Question
  • Updated 1 year ago
  • Answered
Hello All,
I have switches x450, x460, x670 and BD-8806 but i need know the serial number the license Installed actually in the switches.
you know how to get this number for cli ? :)
Thanks.
Photo of Susana Tovar
Susana Tovar
  • 494 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Jefferson Lemos
Jefferson Lemos
  • 338 Points 250 badge 2x thumb
Hi Susana,
you can get this information trhoug this commands:
show licenses
show version
Susana Tovar
Hello Jefferson,
Thanks, but i need the serial number the license edge, you know how to get this number for cli.
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,500 Points 3k badge 2x thumb
Hi Susana,
It sounds like you're trying to get the voucher or key used to generate the license. The switch isn't able to tell you this information.
Thank you,
Brad
Susana Tovar
Hi Brad,
I do not need to generate the license, I only need to know the license number that the switches currently have installed, it is to have an inventory.
Thanks.
(Edited)
Hi Susana,
The switch isn't able to tell you the voucher number, or the key used to install the license.
Thanks
Brad
Susana Tovar
Hello Brand,
Thanks for your information.
Photo of Bin
Bin, Employee
  • 5,370 Points 5k badge 2x thumb
Hello Susana,
Do you have the account for Extreme Portal
You may find Voucher ID and HW Serial Number in your Extreme Portal.
Maybe, the article could help you.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-generate-and-enable-an-EXOS-license...
Best regards,
