I need Solution
I need Solution
Saravanamurthy_
Contributor
Hi Guys,
One my customer using V2110 controller with 27 AP for 3205i. They can only 60 Max binding only. but they need abv 500 mac binding. what solution give to this problem. thanks in advance.
2 REPLIES 2
Ronald_Dvorak
Honored Contributor
I'm not sure whether we talk about the MAC whitelist of the controller but if that is the case the max. limit is 768.
https://gtacknowledge.extremenetworks.com/articles/Q_A/How-many-blacklist-whitelist-mac-addresses-ar...
Christoph
Contributor
I would suggest to use an external directory to manage the clients.It's also more comfortable than using the integrated list of the controller.
For example use Extreme NAC. You can also use a Microsoft AD together with NPS.
Kind regardsChristoph
