I need Switch Model
I need Switch Model
Saravanamurthy_
Contributor
One of customer asking core switch, that is 75 ports 10 G copper + 8 Ports SFP+. so totally their asking 83 ports 10G ports for single switch. i dont know which model is quote for this requirements. pls give the solution for this.
2 REPLIES 2
Gerald_Nuque
New Contributor III
Unfortunately, there's no single switch that will give you 75 ports 10 G copper + 8 Ports SFP+. The nearest you can offer is X690-48t-2q-4c. That will give you 48 10GBASE-T ports and 6 10Gb SFP+ ports. You will need 2 units of this model to comply for your client's requirement.
Eric_Burke
New Contributor III
Take a look at the X690-48T-2Q-4C units. You'd need 2, but it has 48 copper plus 3 QSFP ports which you can fan-out to 12 per switch.
