I need to configure SNMPv3 on NetSight switches and Avaya - Cisco
  • Question
  • Updated 9 months ago
  • Answered
Anyone can share me a script of a configuration switches snmp v3 on Avaya, Huawei and Cisco to work them properly in NetSight?
I appreciate your help!!
Photo of Jairo Rojas Herrera
Jairo Rojas Herrera
  • 1,452 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 4,796 Points 4k badge 2x thumb
Hello,
The following commands should work with Cisco using the default NetSight SNMPv3 profile:
snmp-server group V3Group v3 auth read V3Read write V3Writesnmp-server user snmpuser V3Group v3 auth md5 snmpauthcred priv des snmpprivcred
snmp-servert view V3Read iso included
snmp-server view V3Write iso included
I don't have any examples for Avaya, or Huawei
Thanks
-Ryan
Jairo Rojas Herrera
Thks Ryan
I do not use this snmp configuration for cisco, it gives me an error after this line: snmp-server group V3Group v3 auth read V3Read write V3Writesnmp-server does not allow to add user.
Your contributions please.
Thank you
Photo of James Drennan
James Drennan, Employee
  • 186 Points 100 badge 2x thumb
Avaya VSP:
no boot config flags block-snmp (enables SNMP)
load-encryption-module aes (loads encryption module for AES)
snmp-server view Client 1.3 (permission to modify SNMP settings)
snmp-server user test-user group test-group sha test-sha eas test-aes (created a user “test-user” in the group “test-group” with SHA password “test-sha” and EAS password “test-aes”)
snmp-server group test-group “” auth-priv read-view root write-view root notify-view root (created group “test-group” with read/write/notify privileges)
Avaya ERS Switches:
snmp-server user test-user sha test-sha aes test-aes read-view nncli write-view nncli (created a user “test-user” with SHA password “test-sha” and EAS password “test-aes”)
