I would like to know configure multicast between vlan by MVR on extreme summit x440
  • 2
  • Question
  • Updated 2 years ago
  • Answered
I would like to know configure multicast between vlan by MVR on extreme summit x440. Now, I configure same GTAC Support from link https://gtacknowledge.extremenetworks.com/articles/How_To/How-To-Configure-MVR
but not work. Please help me check for this issue.
Thank you
Photo of Jack TheGiantslayer
Posted 2 years ago
  • 2
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
Please share the configuration of MVR from your switch.
Also, please explain in detail when you say it is not working. I am assuming that you are able to configure it but the traffic is not received by the receiver from a sender in another VLAN.
MVR works based on the IGMP snooping. So, please ensure that you have the IGMP membership report for the multicast group in the receiver vlan. You could verify the subscription for this group using the command,
show igmp snooping vlan <receiver vlan>
Looking forward to your response.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
(Edited)
