I would like to know the difference between 97003-R-BASE and 97003-R-DC-BASE
  • Question
  • Updated 3 years ago
I would like to know the difference between 97003-R-BASE and 97003-R-DC-BASE.
Mainly the features in 97003-R-DC-BASE
Photo of Dharmaraju chagarlamudi
  • 70 Points
  • confused
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Dharmaraju
In Ridgeline the base is the number of licenses that are supported.  The 97003-R-Base is SW service for just Ridgeline with no feature packs.  The 97003-R-DC-Base is the SW support for Ridgeline with the DC feature license installed.  I hope this helps.
P
Photo of Daniel Flouret
Daniel Flouret, Employee
  • 7,470 Points 5k badge 2x thumb
A small correction to Paul's explanation.
97003-R-BASE is the Part # for ExtremeWorks Software Update Service for Ridgeline 4.x Base-50 (Part # 83019).
97003-R-DC-BASE is the Part # for ExtremeWorks Software Update Service for DC FP Base-50 (Part # 83527).
If you have Ridgeline 4.x Base-50 (Part # 83019) andDC FP Base-50 (Part # 83527) you need BOTH 97003-R-BASE and 97003-R-DC-BASE.
