I/G/C/B-Series Sflow Configuration Disappears after a reset
  • Article
  • Updated 4 years ago
Article ID: 14771
Products
I-Series, firmware 6.42.03.0004 and higher
G-Series, firmware 6.42.03.0004 and higher
C5-Series, firmware 6.42.03.0004 and higher
C3-Series, firmware 6.42.03.0004 and higher
B5-Series, firmware 6.42.03.0004 and higher
B3-Series, firmware 6.42.03.0004 and higher
Changes
Configured sFlow ('set sflow...'; 12908).
The configured unit or stack was then reset/rebooted for any reason.
Symptoms
Configured sFlow receivers (except for IP address) have been cleared, so are no longer present in the configuration.
A few error messages may be seen on the console; for example:
Incorrect input! Invalid Receiver index value.
    -and/or-
Incorrect input! First assign Receiver index.
    -and/or-
Incorrect input! Receiver is not associated with this poller instance.
Cause
This is directly related to the NetSight Inventory Manager fix outlined in 13974.
As a result of that fix, most of the sFlow configurations are now only present in Dynamic RAM (DRAM) rather than also being saved to non-volatile Flash memory, so most sFlow commands are not restored after a system reset.
As of the above-stated firmware version, this sFlow configuration loss behavior upon reset now matches what has always occurred upon sFlow timer expiration (13973).
Solution/Workaround
Functions as Designed (FAD).
Workaround: As desired, re-enter the missing sFlow commands.
Photo of FAQ User
FAQ User, Official Rep
  • 13,620 Points 10k badge 2x thumb
Posted 4 years ago
There are no replies.
