IDE 9.4 is interpreting Mac Auth from a Cisco Wireless Lan Controller as a Radius intead of Mac Auth request
  • Question
  • Updated 1 month ago
  • Answered
IDE 9.4 is interpreting Mac Auth from a Cisco Wireless Lan Controller as a Radius intead of Mac Auth request.  This is preventing me from using IDE to authenticate using Mac Auth.
Photo of Brian Holmes
Brian Holmes
  • 192 Points 100 badge 2x thumb
Posted 1 month ago
Photo of Shmulik
Shmulik, Employee, PLM for ExtremeGuest and ExtremeControl
Hello Brian,
Pls check the the device template in the config of this Authenticator (the WLAN Controller) to see if the ‘mac-address source type’ is set to ‘user-name’ instead of ‘calling-station’id’.
Shmulik
Brian Holmes
it is set to calling-station-id...see the attached screen shot
Brian Holmes
Here is the details....
Brian Holmes
And here is the database entry for this MAC address:
Photo of Shmulik
Brian,
Do you have MAC Auth enabled in the Authenticator configuration for that Cisco AP? and also have the appropriate MAC Auth Access Policy associated with that AP?
Shmulik
Brian Holmes
Ok.  Setting ‘mac-address source type’ to ‘user-name’ fixed the issue.  One last related question.  Will changing this option in IDE have any impact on 802.1x authentications or is this setting only used for MacAuth?
Photo of Shmulik
No should not impact. Because you likely have various auth protocols enabled (incl. TLS and others) on the Authentication Policy, and the switch/AP will first attempt to auth via more secure protocols and IDE will respond accordingly.
Shmulik
