IdentiFi: Balancing Users
  • Question
  • Updated 4 years ago
  • Answered
Hi folks,
How are you setting the balancing users? Are you working Balancing Clients or Radio Preference? Or depends on how many devices or types (laptops/tablets/smartphones) with a/b/g/n that I have?
Thanks,
Edson Moura
Photo of Edson Moura
Edson Moura
  • 472 Points 250 badge 2x thumb
Posted 4 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,328 Points 50k badge 2x thumb
Client Balancing should only be used in a certain area were the APs have line of sight i.e. a dense deployment in a large conference room were you expect a lot of client so one AP wouldn't be enough to provide service for all the devices.
So you put all the APs in this one are in a client balancing load group.
Radio Preference could be enabled on the whole network but you should have a good WLAN coverage.
Edson Moura
Thanks, Ronald!
Photo of James A
James A, Embassador
  • 7,492 Points 5k badge 2x thumb
We were planning on using balancing, but with our density and client type (iPads), 70% of clients are on 5GHz, so there's no need for it.
