IdentiFi roaming threshold
  • 2
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Hello, all!
Have 2 questions:
1 - Where can I find configuration for roaming beetween AP's in 1 WLAN?
For example, client with signal worst then -68dB have to roam to another AP.
2 - How can I limit/prohibit raffic beetween Wi-Fi clients?
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,192 Points 10k badge 2x thumb
Posted 2 years ago
  • 2
Photo of Alexandr P
About roaming - is there only Probe Suppression,  Forced Disassociate and OKC?
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,578 Points 5k badge 2x thumb
Hello
For roaming you have the minimum basic rate and power settings to encourage roaming, plus the probe suppression you already mentioned.  Ultimately the roam decision is down to the algorithm used by the client manufacturer, for reference check out these articles:
https://gtacknowledge.extremenetworks.com/articles/Q_A/why-do-my-wireless-clients-not-roam-properly
https://gtacknowledge.extremenetworks.com/articles/Solution/Issues-with-clients-staying-with-an-Access-Point-that-has-bad-signal-Sticky-Clients
For traffic blocking, refer to this article: https://gtacknowledge.extremenetworks.com/articles/Solution/Block-MU-to-MU-enabled-but-users-can-still-communicate/
-Gareth
