Identity Dashboard Engine (IDE) Authentication
Mohamad_Farezza
Hi Team, i have one question, In IDE if i want to use Radius access policy for MAC auth then i need to store the MAC in username format in the user set. My question, it is have the other method ? for example using wildcard just add MAC 6 digit only for IP Phone Avaya, it is possible? i have 1000 unit ip phone, can u suggest me the other method to implementation .
6 REPLIES 6
Mohamad_Farezza
attached below diagram setup .
Mohamad_Farezza
Shmulik
ok, in access policy, can we use both (radius and mac auth) or either one only?
Shmulik
Mohamad,
Take a look at the Ignition Server Configuration Guide for release 9.5.0 page 157 and 158 it shows how it is done. You have to use MAC Auth - see red square on the screenshot.
52d2edd1222441149358caf94af162ee_RackMultipart20181114-16107-1kzwg2i-image_inline.png
Shmulik
Mohamad_Farezza
Fyi, i want to use Radius auth and MAC auth(using wildcard). it is possible ?
