identity management function
  • Question
  • Updated 5 years ago
Create Date: Jun 25 2013 8:42PM
Does identity management can get device os, example os:windows xx
(from Hsu_LiPing)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Jun 27 2013 2:36PM
If you are using Kerberos snooping, I believe the most you can get is the NetBIOS hostname. However, others might know more about this.
(from ethernet)
Create Date: Jun 28 2013 10:13PM
Hey Helpme
No IDM does not do any finger printing functions today.  It can determine a user or device based on Kerberos snooping, MAC oui or LLDP and can then do policies based on the identity.
Hope this helps
(from Paul_Russo)
