Connecting a 100M switch to a 1G switch with fiber
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
If you have one 100 meg switch and one gig switch does the fiber have to have converter so they can see each other.  Is a converter required?
Had a splicer come in to repair fiber between two building one 100 meg and the other is a gig switch
Photo of Wayne
  • 120 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Drew C.
Drew C., Community Manager
  • 36,170 Points 20k badge 2x thumb
Hi Wayne, I've edited the title of this post for clarity.
As long as the 1G switch can negotiate down to 100M, you likely won't need to do any kind of conversion.  Unless you're using something other than OM3 or OM4, you should be fine.  You may need a mode-conditioning patch cord if you're mixing multi-mode and single-mode fiber.
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,354 Points 2k badge 2x thumb
Please provide correct models of both switches and models of SFP transceivers that you plan to use
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,606 Points 10k badge 2x thumb
Hi Wayne,
in general, 100M over fiber is not compatible with 1G over fiber. There exist combined SFPs that support both 100BASE-FX and 1000BASE-SX, but they are not often used because they cost as much or more then one 100BASE-FX and one 1000BASE-SX transceiver together.
100BASE-FX uses the same fiber cables as 1000BASE-SX (multi-mode fiber, MMF). You cannot passively convert between different fiber types, you would need an active converter (e.g. a switch with both types of transceivers).
Best regards,
