Import / Move, Roles / Rules between domains in Extreme Control
  • 2
  • Question
  • Updated 12 months ago
  • Answered
Just wondered if there is a means to just port specific Roles / Rule between domains. It looks like you can do it on mass, but not individually.
The reason I might want to do this, for example:- I have a test domain and want to port roles / rules over that I've tested working, or I simply have some in other domains that I would like to replicate.
It looks like you can copy Roles / Rules within the domain, but not between domains, but then again I could be missing something?
Many thanks in advance.
Photo of Martin Flammia
Martin Flammia
  • 6,108 Points 5k badge 2x thumb
Posted 12 months ago
  • 2
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,548 Points 5k badge 2x thumb
1. You can import all roles/services/rules and later delete those you do not want.
2. you can copy services to global services and use the same service in multiple domains.
Regards
Z.
Martin Flammia
Hi Pala,
Thanks for getting back.
The first option is a problem in my case, as I wouldn't want to overwrite, replace, or merge anything in my production domain with those from my test other than the ones I want obviously, but the second option could possibly work.
Will give it a go.
Thanks
