Impossible to activate ssh in Extreme X450a-48t Switch after loading ssh module
  • Question
  • Updated 3 years ago
  • Answered
I have an Extreme X450a-48t Switch currently having version below:
Image Selected:   secondary
Image Booted:     secondary
Primary ver:         12.5.3.9
Secondary ver:    12.5.3.9
Config Selected:  primary.cfg
Config Booted:    primary.cfg
primary.cfg       Created by ExtremeXOS version 12.5.3.9
                         222397 bytes saved on Thu Feb 26 01:53:00 2015
I have downloaded the ssh module and installed successfully in both partitions:
download image 159.107.39.6 summitX-12.5.3.9-ssh.xmod vr "VR-Mgmt"
Do you want to install image after downloading? (y - yes, n - no, <cr> - cancel) Yes
Downloading to Switch..
Installing to secondary partition!
Installing to Switch.Error: Failed to install image - Package exists, please uninstall existing package first
Same error for primary, however I can not activate ssh with "enable ssh2" command. I have rebooted the switch as well as run update with no success.
Any help, on how it might be possible to activate ssh on the switch? What it might be happening??
Thanks, Jesus
Photo of Jesus Rodriguez
Jesus Rodriguez
  • 110 Points 100 badge 2x thumb
Posted 3 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
see if you can start/restart process exsshd
If this doesnt work out then we have to move to a different exos version
and install ssh module try.
The reason to go for a better exos version is
1.This might be a bug in 12.5 which has already been resolved
2.12.5 is End of engineering
with X450a you can use EXOS till 15.3.x
Jesus Rodriguez
Apparently I can not start/restart exsshd process.
SW_A2_OAM_ERICLOUD_01.1 # restart process "exsshd" Step 1: terminating process exsshd gracefully ...
Error: Process exsshd was not started due to insufficient license
SW_A2_OAM_ERICLOUD_01.2 # start process "exsshd"
Error: Process  exsshd is not licensed to run!
SW_A2_OAM_ERICLOUD_01.3 #
So, do you recommended to install 15.3.x Version? When I request the latest software from the Extrem page (Using the Serial Number) the latest one that I was offered was 12.5.3.9 that is why I installed this release. If you confirm that 15.3.x is valid I will try to download it from extreme web page if I am allowed...
Regards, Jesus
Yes go for 15.3.x
Jesus Rodriguez
Done. I uploaded the proposed version and fixed the problem. Thanks a lot for your help...
awesome you've fixed the problem.
