In switch LAG , 1 port taking more traffic than others.
  • Problem
  • Updated 11 months ago
  • Solved
We have extreme inter switch with 7 ports in LAG all in different slots.
And we can see 1 of the 7 ports is taking high utilization apart from other 6
As these on different slots, so any input on the issue.
If anything can be checked, (no errors/no congestion) but in peak time sometimes we get ping drop.
show port 1:4 1:5 2:13-15 2:19-20
Port     Link    Link   Rx             Peak Rx       Tx            Peak Tx
         State   Speed  % bandwidth    % bandwidth   % bandwidth   % bandwidth
JBCIMS-U> A       1000     16.35         36.00         29.97           69.66
JBCIMS-b> A       1000     15.42         36.51         14.90           35.03
EVO_Cont> A       1000     31.43         74.81         14.30           32.22
RNCVKIRJ> A       1000     15.50         36.19         14.54           32.33
To_JAISW> A       1000     15.53         40.01         14.61           35.58
RJGMSC5_> A       1000     15.93         40.32         14.81           34.99
RJGMSC4_> A       1000     16.37         40.78         14.88           36.04
Photo of Saurabh Makkar
Saurabh Makkar
  • 232 Points 100 badge 2x thumb
Posted 12 months ago
Photo of Kawawa
Kawawa, GTAC
  • 3,200 Points 3k badge 2x thumb
It really depends on the characteristics of your traffic and the hashing that is being used when determining what link to forward a stream across.  Are you able to confirm what algorithm you're currently using and whether the traffic traversing the LAG is from a specific device. LAGs are primarily designed to aggregate multiple links as opposed to provide load balancing.  Therefore if you have (say) the same two devices talking across the LAG, with an L2 and L3 algorithm, these streams will most likely be forwarded over the same LAG port.
(Edited)
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Saurabh,
In addition to what Kawawa posted, you may want to take a look at the following GTAC Knowledge article:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Why-is-traffic-distribution-across-ports-in-a...
