in xtreme switch summit x460 24t how to configure q in q vlan ?
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Photo of Pushpendra Sharma
Pushpendra Sharma
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,288 Points 3k badge 2x thumb
Hi Pushpendra,
TheVMAN technology is sometimes referred to as VLAN stacking or Q-in-Q.
I have included the EXOS 16.1 User Guide link below for your reference. Please refer chapter-14 VMAN, there is a sample configuration provided
http://documentation.extremenetworks.com/exos/downloads/EXOS_User_Guide_16_1.pdf
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,526 Points 3k badge 2x thumb
Hi Pushpendra,
Please find below KB article for configuring VMAN in EXOS,
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-a-VMAN-in-EXOS
Let us know if you have any further questions.
Thanks,
Suresh.B
Pushpendra Sharma
i get
* X460-24t.1 # enable jumbo-frame ports all
* X460-24t.2 # configure vman ethertype 0x8100
* X460-24t.4 # create vman dt tag 2                              ^
%% Invalid input detected at '^' marker.
So my question is what should I replace tags with ? Is it outer and inner vlan with a separator ?
Another thing - i guess ethertype is outer vlan type . I could use 9100 or 88a8 (in 0x) too . Am I right ?
Hi Pushpendra,
 The switch vlan (dot1q) table is common for all pvlan, vman, vlan aggr and others.
 create vman dt tag 2 -àouter tag
 If switch has same tag 2 configured for other vlan we could not able to use the same tag. So it must be different tag number than the local vlan.
 This is for outer ether type and you can configure other ether types as well.
 Note: Ports added to Layer 2 VPN service VPLS/VMAN should not be part of PVLAN or VLAN
aggregation.
Thanks,
Suresh.B
Photo of MANAS BEHERA
MANAS BEHERA
  • 210 Points 100 badge 2x thumb
Hi Pushpendra,
Please follow the link.
https://community.extremenetworks.com/extreme/topics/vman_qinq_on_summit_450-nwxcj
Regards,
Manas Ranjan
