In X440 switches, how can I know the speed of the port by looking the LEDs on the front pannel?
  • Question
  • Updated 4 weeks ago
  • Answered
Photo of Rodrigo Gomez
Rodrigo Gomez
  • 132 Points 100 badge 2x thumb
Posted 4 weeks ago
Photo of Drew C.
Drew C., Community Manager
  • 38,410 Points 20k badge 2x thumb
Hi Rodrigo,
There is no way to determine link speed by the LED on the front panel of an EXOS switch. The only think you can tell is if the port is delivering power via PoE, in which case, the LED will be amber instead of green.
(Edited)
Photo of Leviodjos
Leviodjos
  • 158 Points 100 badge 2x thumb
The LED blinking has nothing to do with the speed. The only think I can say is that when there is more traffics passing through the port, it blink faster. In idle time, when the end device goes to sleep mode, the LED blinks slowly.
And as Rodrigo mentioned, the LED is amber when the port supply power (PoE), and green when no PoE.
By also watching the behavior of the LED you can also figure out if a port or a connection as an issue.
Thank you!
Photo of Leviodjos
Leviodjos
I meant Drew C. Sorry man!!!
Rodrigo Gomez
Thank you very much Drew and Leviodjos
